Pop pressure
CUCV
SE Pennsylvania
I know I read this before on here, but can't find it.
I have 6.5 NA injectors that are like new and want to replace the crappy marine injectors on my truck.
IIRC, I could use the N/A ones, because the aperture is the same, but the pop pressure is different. I think missygoodwrench had the details on this. Was it 1100p.s.i.?
Any help is appreciated.
Thanks in advance.
-Paul
Stock they are about 2100psi. If you are running more boost than stock I would up the pop to 2200psi and make sure they are all within a 50psi range or less, like 2180psi to 2230psi.
I know some shops dont measure that accurately, but having them balanced is ideal.
No boost changes. Wonder if I should just do 2200 in case I throw a TM on later........
Thanks for the info.
I would do 2200 anyway, because likely to get TM or PCM upgrade in the future sometime. And the pop settles lower than its set anyway. The marine injectors are set a little above 2200psi stock.
Hey Buddy reading ur signature. What filter r u using as a prefilter and what is the threads? Where can I read about ur Amsoil Nano filter behind headlamp future mod? Sorry for going off topic CUCV. Whats cucv anyway?
Thanks in advance.
-Paul
Here you go: http://www.thetruckstop.us/forum/showthread.php?21150-Resetting-injector-pop-pressure Your welcome
