jrsavoie
Recruit
!998 K2500 Suburban 3.73 gears
We overheated 3 times between Pagosa Springs and South Fork on Rt 160 while pulling a lightly loaded trailer - about 1200 lbs. - plus the weight of the trailer. We were blowing plenty of black smoke.
I'm going to have to jack the trailer up and make sure the wheels were turning freely - though there was nothing to indicate they weren't.
We ran the whole trip at normal temp til the big hill with the trailer.
Subsequently we warmed up over 210 when driving up to Zapata falls
About 2 1/2 hours from home the Check engine light came on. It went back off before I took it to get the code read.
I didn't get the number in history but the code was something like turbo high voltage.
The Suburban was still blowing black smoke when revving with no load.
Other than that it seems to be running fine
We couldn't figure anything else out that would be wrong. The PMD is an older Flight Systems. I'm going to try one of my spare PMDs
I got very lucky on my trip. I tried the spare PMD we had in the counsel and found that it was the bad PMD from the last time I changed it. I must have forgotten to pull the resistor, toss it and replace it.
Any ideas or suggestions? Other than to make sure your spare PMD is GOOD and not the bad one you previously replaced.
