PMD pins?
Can't make since of it. What are you doing?
Sounds like you need 2 males back to back to go between females.
i didn't know they made a male connector......yes wanting to connect 2 female plugs......the reason i said it as i did was the other male connector i seen was just pins and shrink rap.....
"they" don't, but I can:)
Its confusing because the female plastic body has the male pins in it and vise versa.
You want a way to connect two of these
or these together?
Got a picture of what you have?
what has happen my 95 burb caught fire under the hood and burnt the connector for my remote PMD.....so i end up with 2 female(your bottom pic) and was needing a double male......i looked at the old cable last night and it had melted the wire under the loom......so i just got a new 6ft cable.....thanks for looking into it....
AHH, I could have done it, but it would be a rig. Better that you got a new cable.
BTW I dont see a cable order? Just want to make sure if you ordered it from me then you may want to check for a confirmation from your payment source.
