D2 Cat
My understanding is the PMD generates heat and without dissipating it early failure results. With the PMD in the original position the engine heat adds to the problem. So the solution is to relocate the PMD to a cooler place, and part of the solution is to include an aluminum heat dissipater.
So, when I look at a PMD the power transistors are counter sunk in the back of the housing a little bit. My understanding is the case of the transistors functions as an integral part of the transistor and should not contact another surface.(That's why they are countersunk) The transistors generate the excess heat.
The heat sink I have seen are a flap piece with the cooling fins on the opposite side of where the PMD is mounted. And the PMD is mounted with specific heat transferring substances.
My question is: Wouldn't it be much more effective if the heat sink had two open spaces to match the case of the two power transistors to allow the heat to escape to the open air? Not to contain it and transfer it to the aluminum to dissipate?
Just doesn't make sense to contain that heat.
If the PMD is located behind the license plate without a heat sink the hottest air passing it would be about 110 deg. in Kansas. Why does that even need a heat sink?
