USMCGrl
okay I have a 99 GMC burb, has been running great. PMC replaced and relocated roughly a year ago. Fuel filter replaced a month ago. IP replaced before I bought it roughly 2 years ago. I'm starting to get really frustrated with all the issues and need someone to point me in the right direction for the latest no start. Drove back and forth to town friday, sat, and sunday, no problem, truck cranked up like normal everything seemed fine.
Tuesday I go out to start the truck and it won't turn over, it cranks but won't start.
check for fuel at the filter top screw valve, I HAVE FUEL, so pump seems to be working I was able to check 5 of the glow plugs and all tested good with multimeter. couldn't get to the other 3, checked all the fuses, Batteries are good. I'm at a loss, leaning towards gp relay??? so I plugged in the block heater to try and help everything out, it hasn't been that cold, but it didn't seem to make a difference anyway. did smoke a little when starting up, but it always has. :mad2::mad2::mad2:
