Pictures
Butch
Texas
I hope this works.Here are the pics on the stack I put on the truck.Hope ya like them. I think it makes the truck look like a big rig setup.Click on the picture & itll make it bigger to see better.
it deff makes it look more like a big rig it came out nice i think it would look better with duals and with the strap up top closer to the bed
Unique. I like it...:)
Glad you got the pictures working.
Stack
I would have put the brace down were your talking about except when you take the inside :eyebrows:plastic liner out to bolt it on you'll find a double metal liner inside & it goes up almost to the top of the cab.Im right above the double liner inside.Were it is is thats were the double liner ends.Must be for support on the cab.Took the back seat out & inside plastic liner to get at the single wall liner.I also used rubber groomets in the holes to mount the stack bracket to eliminate the vibration through the cab.Tried to copy a big rig setup.Also had to make the stack bracket because you cannot get one unless you go to 5" or bigger.
Mileage & Performance
I have a 01 3500 D/A here & just turned the 104,000 mark without any problems since I bought the truck new in 01.This thing has bene a gods send to me.Getting 16-18 empty & 6-8 pulling.Pulling 26,600 truck & trailer with all the power I need to get the job done.The ole girl has passed a lot of fords & dodges going up the hills , mountains out west on the big road too.Dont even use the tow-haul unless in town or pulling up or coming down the grades.Bene through 3 sets of rubber averaging around 50,000-60,000.The engine is a LB7 & has never failed me yet.It purrs like a kitten.Anybody else got one of the first ones built back in 01? How are your trucks performing?:)
Stack
at least you found a way to mount it so how does it sound?
A little noisy & with a rapping sound .Sounds better if you use the tow-haul when ya come to a light or stop sign.Itll rap louder then.You can also hear the turbo whistle if you use the tow haul & let off on it.Sounds just like a big rig except with no smoke.:)
Damn I like that! Sharp truck! I wish I would have done mine that way, no bed space lost! Good job!
