pacificdrumma
I have decided that for the time being, I am so far into my truck $ wise that I am better off keeping it and driving it till the doors fall off. Its got 161k right now and its pretty clean for what it is. By non-performance supporting mods I mean things you can do to make the truck run healthier- oil cooler lines, cooling mods, etc. Part of keeping the truck is going to be blasting and painting the frame, and cleaning everything up underneath. I would like to degrease the front of the frame around the engine, and I figured if I'm gonna be in there I might as well do braided oil cooler lines, check out the rad., etc. So far the truck is stock. Relocated PMD, homemade intake, exhaust, and turbo master. Has good batteries, glow plugs, alternator, turbo, IP, etc. Runs drives stops starts just fine. Plans are 4" exhaust, k47 box, injectors, FRC10. After that, depending on how things go, ATT and chip. That said, what are some things I can do to make the truck healthy and ready to support a little more power? And pics of your installs would be great.
