Pillow
Recruit
Okay here is an odd one. The '99 Burb crapped out all of a sudden and will not turn on at all. When the key is engaged all the dash lights come on and nothing happens at all when it is tried to start up. No fuel pump, no starter, nothing!
I pulled the ECM-1 20A fuse under the hood and I can get the starter to turn with the key and the lights on the dash go away.
I then put the ECM-1 fuse back in and took out the PCM. Which netted the same result as pulling the fuse. I can get the starter to turn with the key and the lights on the dash go away.
Seems to me the PCM crapped out..?
... I am now missing the "brain" to make the rest work. Anyone have a loaner? For a 99 Burb 4.10 Auto-track
I just want to see that the PCM is the problem or something else has gone whacky.
FWIW the PCM is a Heath GL4.
Thanks,
Thanks,
