bfourman
I installed my new Walking J/KOJO tuned ECM this afternoon, and the truck performance is outstanding! I am having an issue with DTCs though. I did the KOKO procedure as advised by Patrick, no problems there. I am getting a P1643 code, which on my scanner is a Fuel Pump Control Circuit fault. Once I clear it it doesn't come back on on restart as long as I have the scanner plugged in. As soon as I unplug the scanner and start it, the SES comes back on. The WTS light comes on, the glow plugs cycle and the lift pump purrs away, but the light comes back. I never had a light with the stock ECM.
Any ideas? I don't have access to a TechII or anything past a OBDII scanner so I can't give info on timing or otherwise.
Truck and mod info in my signature.
