Rodd
Recruit
I was just up in the mountains with my kids doing some off roading nothing extreme. Forest service roads that need 4x4 to get through. I was doing about 5 mph up the steep rocky roads and on my way down I noticed my check gauges light was on and my temp was on the next longest line between 210 and 260. As I climbed hills it got higher. We were between 4 & 5k feet elevation and the temp was between 85-90. I did replace the water pump and flushed the whole system about 10 months ago so everything was good there. I was also running my A/C which probably contributed to the overheating. Is this a normal thing for you guy's that use your 4x4 in the heat?
Thanks!
Thanks!
