You were pretty vague in your 1st post, that's why I was trying to get some details. Have you tried cleaning and re-installing your origanal VSS? Have you checked for play in the transfer case where the slip yoke goes in? It isn't uncommon for the tail shaft bushing to get loose, let the tail shaft drop down, and this increases the clearance between the VSS and tone wheel making it slower to pickup and read when it is moving.I replaced the vss because i thought that the was my problem with my speedo i bought it from the dealership.
The tranny shifts easy when it finally shifts out of first it was rebuilt less than 5000 miles ago and didnt start the slow shifting till the speedo started acting up
