GM Guy
Manual Trans. 2WD Enthusiast
hey all,
working on the sister's 2000 Pontiac Bonneville with the 3800 V-6.
The issue is with the HVAC. It has the manual system with two knobs and 8 buttons, rahter than the little digital display. It blows warm when selected to cool. with 250K miles, the knobs are well used, and the temp selector is sloppy. you can turn it to cool, and go one "notch" at a time, and get a fairly large temp change, so I am wondering if the control module (the whole mini-dash unit, with 2 knobs and buttons) is wore out and needs changed, or are these cars famous for bad blend door actuators?
no matter what, I hear this car has CANBUS, so I am worried that I may need to have a tech II involved to change any parts electronic, as in get the CANBUS system to "recognize" the new parts. is this true, or can I change whatever with the battery unhooked, then hook it up and be fine?
finally, is there any way a tech II can aid in the diagnosis? I may take it to our local dealer if this CANBUS system is too much for me.
on a side note, we just put a can of freon in, and now it blows cool (had 15 lbs in the system, so just added freon. dad insisted on adding an ounce or so of ester oil against my recommendations) but not cold, so we are still combating the issue of heat intrusion into the system.
any input appreciated, thanks!
