Darkrider
Lobo Solitario
Ok given that the problems that im having with my truck started after taking it through the car was I am wondering if the bypass wiring on the lp wasnt damaged by the high pressure undercarrage wash. The way the wiring was done was that the original power wire from the ops was cut and taped off, then a wire was ran up to the fuse box. Now the wire to the fuse box was joined together by one of those marrionette (sp?) Caps that you usually see in house hold electrical comnections, I have honestly been warry about this from day one. So im planning on doing what leroy has suggested to me in a couple other threads and that is return to using the ops as my trigger for the relay.
Now my question is this will 14 ga wire be heavy enough for this or should I pick up some 12 ga? Also what size of relay will I need?
I plan on using spade connectors at each connecton between the trucks wiring and the new harness, the type of spade connectors im using have interlocking covers on them for a weather resistant seal, plus I plan on sealing them to the wires with heat shrink tubing and wrapping the connection itself with electrical tape that way I can quickly disconnect the relay harness from the truck should I ever need to to run without the relay in the system.
Sent from my SGH-T959D using Tapatalk 2
