gnel
I am still having random stalling problems and was sure it was the 2 PMDs I have. Well today I started checking fuel flow to see if maybe that was it. So I replaced the fuel filter and then checked my flow from the water drain valve I had none. I opened it all the way and the truck died. I checked the pump with the motor off and it was pumping away. I had an old OPS that I had replaced last year with a new ac delco. Viola Good flow and pressure at the WDV. The trucks out in the yard purring like a kitten:mad2:.
Could a bad OPS have been my problem all along? It doen´t seem likely. What could cause the death of my OPS after only a year. I was still showing oil pressure with the bad OPS is that normal?
This is stressing me out as I´m driving this truck up to the states in a week. Thanks for any replys gus
