allproroofing
Hey all , fairly new to diesels and need some advice. I have a 1993 k3500 dually 6.5 turbo diesel with 128,000 miles. I know I need to replace the injection pump , but just don't have the money right now , so I've been doing the cool water on the IP thing when it gets heat soaked and seems to be working for now. I guess my first question is should my lift pump be running to prime the system before it fires up? I have hard starting issues to begin with. second question , If I wired a toggle switch into the lift pump and let it run for 10 seconds or so before trying to start , would this clear the hot thin fuel out of the injection pump through the return line enough to fire it after being heat soaked? So far , I have replaced the cdr , ops switch , ops relay , 2 new 850cca batteries & new glow plugs. Also installed a glow plug over ride button. Any help would be greatly appreciated.
