great white
So, I'd like to discuss why the factory boost control system is seen to be "not so great".
I just finished installing my Auber boost guage and have a day or so of running with it.
From watching the readings, it seems the factory program does a relatively decent job in the way it manages the boost.
For example:
On just a drive to work, the boost is anywhere from 0-.5 PSI on a nice flat run once the throttle is steady and load% is leveled out. Good for MPG IMHO.
Throttle application brings the boost up pretty quick to around 5 psi and I have seen a max spike of around 11 PSI on heavy throttle punch (but only a few seconds and then it dials back). As the load comes down, so does the boost.
Climbing up a hill has the PSI at a pretty much steady value somewhere around 3-7 psi, depending on the hill, throttle position and load %.
Trans shifts have the boost backed off for shifting and then ramping back up after gear change. This makes sense from a longevity point of view.
From what I'm seeing, it seems like the factory program manages the boost fairly well for MPG and modest performance.
The "complexity" of the vac system isn't a big deal to me. Just another system to be maintained properly. Fact of life on "newer" vehicles.
Keep in mind, my truck is mostly a commuter, so my needs for boost might not be the same as someone towing heavy loads or looking for "speed" out of a 6.5.
I can make a short vid of my display and values if anyone wants to see for a frame of reference.
Feel free to discuss.....
For example:
