RCpullerdude
- Messages
- 229
- Reaction score
- 3
Problem started back in January. Was driving along, made a turn, then once accelerating again, had a small loss of power and slight black smoke. Progressivly got worse and started making noises. New fuel filter, tried new fuel, new turbo, plenty of vacuum at wastegate. At time of last run, it couldn't do 20 MPH up a very slight hill. Parents decided we'd change injection pump. Did so (used injection pump off eBay real cheap, probably bad), and now won't run period with two different injection pumps. Gets fuel all the way to the pump, but none out injection lines.
- Year: __1994____
- Truck model and class (ie: c2500) ____K1500_____
- Automatic or Standard _____4L80-E_____
- Mileage: (indicate miles or km) ____192K Miles_____
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ___IP, intake, Heath PMD, 3" downpipe and cat to 4" exhaust (not plugged)________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ______"S" L56 EGR, Turbo________
- Ambient outside temp: (indicate *C or *F) _____Between 40 and 80 F_____
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ___#2 Winter blend______
- What fuel additives are you using? ___Power Service White bottle________
- Where are you located? ____NW PA_________
- Air filter _____Freshly cleaned____
- Fuel filter __Brand new_______
- CDR Valve? ____Tests fine_____
- Coolant – last flushed/replaced at _____Unknown________
- Oil – synthetic/regular, changed at ____Regular 1.5-2K miles ago_______
- Batteries – state of charge, (matched set) replaced at _____Brand new matched________
- Battery cables and grounds (removed, cleaned and tightened): _____All clean and tight_________
- Glow Plugs - how many miles on them? ____Probably 10-15K_____ What type? ______SSD Instant Heats (probably bad, but started fiarly well in much cooler temps than this)_______
- Injectors - last changed at _______Probably 180K or so________
- What were you doing when it happened? ______No start, just replaced IP Smoke, turned a corner________
- How was the truck running fine before this problem appeared? _____No start, it was smoking and had no power Smoke, perfectly normal________
- Has this problem ever happened before? ________Niether has_______________
- Describe any related factors that might be part of the problem. ______None________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __Yes__ And? ___None, at all_____
1a] Does the engine start? ____No_____
1b] Does the engine crank over? ___Yes_____
1c] Are your batteries fully charged? ___Yes______
1d] Have you removed, cleaned, and tightened all battery connections? ___Yes_____
1e] Does your Wait to Start light come on for a time? How long? ___N/A______
1f] Does your glow plug light come on? _____Yes____ For how long? ___5-15 seconds, depending on conditions______
1g] Do you see smoke from the exhaust while cranking? What color? ___None_____
2a] Can you hear your lift pump working? _____Yes_______
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ___Yes______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ____Yes_______
2d] Loosen an injector line and crank the engine - does fuel come out? ___No______
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? _____No______
3a] Location of PMD (on pump, on intake, remote mounted) ____Heath Remote mount_______
3b] Condition of Extension harness (if used) Vendor or Homemade? ____Heath, good condition_____
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ___All good.______
3d] PMD Make: ____Stanadyne_______
3e] PMD Age: _____Little over 1.5 years________
When we put the original pump back on, it started, ran real rough, then stalled. It would then occasionally start, run real nice, then stall within 2 minutes or so. Before long it wasn't starting at all. No rhyme or reason for start. Tried two different PMD's that where known good, still no go. Put other pump on, still no go. Please help. I'm literally at my wits end with this thing.
- Year: __1994____
