MattZ71
Tennessee Diesel's Mod
i no that yall are getting tierd of answering PPE question, but will that 225 tune EVER starve for fuel?
can u run the 225 tune with out a lift pump?? or will it throw a low pressure fuel code at higher RPM's
can you give me some exaplems of a "flow through" is TTS duals one of them?
Yes, TTS Duals are Flow Through. I don't know of any others that are. I know they are out there, just don't know what ones.
I am running the 325 tune with no lift pump and I have not thrown a code yet. I have an LLY and I also have shim kit in it. I have not drilled the fuel rail fittings yet either.
I'm doing a Dual TTS I'm pretty sure. ... NEED MORE FUEL ... MUST GET MORE FUEL ...:devil:
