tightgroup
Any thoughts on an aux or bigger fuel tank for the Burb
Make sure the tank you get is baffled. Makes 'ice' skid recovery a little easier as the fuel slosh doesn't un-stick the tires after they grab.
43 gal stock tank isn't enuff for you I was getting 860 miles on mine before going with the ATT
So a burb tank can in theory be put in a truck in combo with a stock tank, or to replace the stock tank? Very interesting! This is assuming one doesnt mind the spare in the bed.
Having a 600 mile range in the burb is nice, but it sure whould be nice to have an even larger range!!! Adding an extra 26 gal would add about an extra 400 miles. That sure would be nice.
Colby
Yes 3:42s on 2wd and before the BS flag is called out, that was a topped off full tank, to sucking air sputter/shutdown I was 1 mile from the fuel station out in the country on way to town to get fuel.
My fuel gauge had been acting up, trip counter set to 0 when it was filled (packed to rim), I had 5 gal in back with me just in case. Started the trip running 75 mph maybe 250 miles of that speed then 60-65 mph with some 30, 45, 55 mph in there as I was passing through small towns with small town speed zones. Found a place in way out country side with a portable band saw mill I could not pass on the deal on.
Actual odometer was 864 miles when I started running out of fuel maybe 1-1.5 gal left in tank, I was in a hilly area and was sputtering/cutting out, the FFM wasn't air bound but close some air out the top of the FFM vent when I added the 5 gal in the tank to get me to the fuel station.
I don't know what the ATT mileage is for sure as I didn't have it on there long before parking it for a body swap 24-25 ish was what I think I was getting by rough calcs topping off fuel fills to gal consumed, I had planned another full to empty run on purpose this time to see what exact mpg was but never got around to it.
On my truck with the 26 gal tank range was extended with ATT from 385 miles @ 75/80 mph avg to 440 miles with my 3:73s not every truck experiencing this much of a change avg 1-3 more mpg for most that have installed one.
