? on Power Steering Pump w/EVO
TMHark
Hudson, NY
Swapping out my leaking Power Steering Pump w/EVO (what a PITA)
All apart except the 3 hoses.
The high pressure hose is really on there and won't budge (afraid it will break/strip).
Can I leave the high pressure hose and EVO assembly together, and swap as one unit?
If so, what holds it to the tank?
I've pull the two rings off the end, not sure what else hold it on except rust....
Thanks,
I'm not aware of any truck with hydro boost brakes that uses tehEVO system. As far as I know that was only an option on the 1500's with vacuum brakes. As for getting the line off, I would pull the pump and line off together, and clean it off with brake cleaner, then spray it in penetrating oil, and heat it with a torch right on the nut and see if you can get it off that way.
My wife's 98 1500
and my 98 2500 HD has it, i should say "had",cause i pulled the connector on the pump cause of to many near accidents when i lost sudden steering.
That line nut will give,..just reef on it harder.
If you're afraid to round the nut and you can reach the nut from above,use a piece of rod or flat bar on the side of the nut near a hex edge and give it a couple hard raps with a hammer,then use the wrench again..i loosened many tight nuts like that that wouldn't budge with just the wrench.
IIRC matt bachands 97 1 ton had it also.
Hadn't ever seen an OBD2 with it as I'm pretty sure my buddies 00 3500 6.5L didn't have it. And I know GM did away with it for the new GMT-800 trucks as my 01 donor truck sure didn't have it as that pump is in my BURB right now.
got this off of rockauto it's a cardon pump
Vehicles This Part Fits
Make
Model
Year
Chevrolet Trucks
C1500 Suburban
1998-1997
Application Data:
Diesel and (Supplied w/EVO Component) and w/JB8, JD7; w/o Aftermarket filtration improvement; GM Brake Codes are on the "Service Parts Identification" sticker.
Chevrolet Trucks
C1500 Suburban
1999-1999
Application Data:
Diesel and w/JB8, JD7 and (Supplied w/EVO Component); w/o Aftermarket filtration improvement; GM Brake Codes are on the "Service Parts Identification" sticker.
Chevrolet Trucks
C2500 Pickup
1999-1999
Application Data:
7.4 Liters and (Supplied w/EVO Component); w/o Aftermarket filtration improvement
Chevrolet Trucks
C2500 Pickup
1998-1997
Application Data:
6.5, 7.4 Liters and (Supplied w/EVO Component) and w/JB8, JD7; w/o Aftermarket filtration improvement; GM Brake Codes are on the "Service Parts Identification" sticker.
Chevrolet Trucks
C2500 Pickup
1999-1999
Application Data:
Chevrolet Trucks
C2500 Pickup
2000-2000
Application Data:
w/Hydro-Boost and (Supplied w/EVO Component) and w/JB8, JD7; w/o Aftermarket filtration improvement; GM Brake Codes are on the "Service Parts Identification" sticker.; Hydro-boost Pump has 1 Pressure Line and 2 Return Lines.
Chevrolet Trucks
C2500 Suburban
1999-1997
Application Data:
Chevrolet Trucks
C3500 Pickup
2000-1997
Application Data:
w/2 Wheel Disc and (Supplied w/EVO Component); w/o Aftermarket filtration improvement
Chevrolet Trucks
K1500 Suburban
1999-1997
Application Data:
6.5 Liters and (Supplied w/EVO Component) and w/JB8, JD7; w/o Aftermarket filtration improvement; GM Brake Codes are on the "Service Parts Identification" sticker.
Chevrolet Trucks
K2500 Pickup
1999-1999
Application Data:
Chevrolet Trucks
K2500 Pickup
1998-1997
Application Data:
Chevrolet Trucks
K2500 Pickup
1999-1999
Application Data:
Chevrolet Trucks
K2500 Pickup
2000-2000
Application Data:
Chevrolet Trucks
K2500 Suburban
1999-1997
Application Data:
Chevrolet Trucks
K3500 Pickup
1998-1997
Application Data:
Chevrolet Trucks
K3500 Pickup
2000-1999
Application Data:
Chevrolet Trucks
Tahoe
1999-1997
Application Data:
6.5 Liters and (Supplied w/EVO Component) and w/JD7; w/o Aftermarket filtration improvement; GM Brake Codes are on the "Service Parts Identification" sticker.
GMC Trucks
C1500 Suburban
1998-1997
Application Data:
GMC Trucks
C1500 Suburban
1999-1999
Application Data:
GMC Trucks
C2500 Pickup
1999-1999
Application Data:
GMC Trucks
C2500 Pickup
1998-1997
Application Data:
GMC Trucks
C2500 Pickup
1999-1999
Application Data:
GMC Trucks
C2500 Pickup
2000-2000
Application Data:
GMC Trucks
C2500 Suburban
1999-1997
Application Data:
GMC Trucks
C3500 Pickup
2000-1997
Application Data:
GMC Trucks
K1500 Suburban
1999-1997
Application Data:
GMC Trucks
K2500 Pickup
1999-1999
Application Data:
GMC Trucks
K2500 Pickup
1998-1997
Application Data:
GMC Trucks
K2500 Pickup
1999-1999
Application Data:
GMC Trucks
K2500 Pickup
2000-2000
Application Data:
GMC Trucks
K2500 Suburban
1999-1997
Application Data:
GMC Trucks
K3500 Pickup
2000-1997
Application Data:
GMC Trucks
Yukon
1997-1997
Application Data:
Well as per my other thread on loosing fluid from the cap my 97 has it. I read somewhere I thought that 96 and on has it which would correlate with the move to OBDII.
Cheers
Nobby
Cheers
Nobby
I know 96 didn't have it as GM didn't release it until 97 to compete with JEEP who was bringing it out in 98.
