great white
When I bought my 98, the PO told me the engine had been replaced with a 99.
Not being specifically knowledgeable about the 6.5 td at the time (other than my automotive background in gassers), I took that to mean a 1999. She's pretty loud on start (I'm thinking even for an IDI diesel) and quieting down after about 30-60 seconds of running, and she's got a fair bit of blowby, so I've been making plans to rebuild another engine in the not so distant future.
But, today, I felt the need to check out the block casting numbers. There's a few things done to the truck that would indicate someone in it's previous life had a bit of a schmeck (PMD relocated, high idle mod, etc) about 6.5's and I wanted to check out that casting numbers. Besides, I was under there anyways checking out my crossover pipe (sure enough, it's rotted, that's another story) so I snaked my inspection mirror up there.
I was expecting to see a casting number that ended in 506, as you would expect in a 1999 engine. I maneuver the flashlight and mirror a bit, and then the number comes up out of the depths of the darkness like titanic must have for the first explorer to find her:
10148599 (edit- some digging seems to indicate it should be 10149599, have to go look again)
599?
What the hell?
It's a 599 block.
Maybe the guy who sold it didn't mean 1999, but 599.
Someone care to give me the meaning of the rest of the casting number because I'm pretty sure a 599 block wasn't available in 1999....
Now I need to check out those heads. Anyone know where I can find those casting numbers?
How does this effect the "F" in my vin? I'm thinking the heads and block are the same, just the bolt on bits and the PCM.....
Should I be happy or p!ssed that the block is a early 90's vintage?
I'm not taking the pan off to check for cracks either....too much trouble right now and I just don't want to know....
599?
What the hell?
It's a 599 block.
