OK, no bullshit...transfercase fluid you have used
richard cheese
the MAIN muff hugga
I am seriously in need of changing my tcase fluid....i posted a thread on "the site that shall remain nameless" and got a bunch of dumbasses' opinions, not the fluids they use
Seriously....
please list the year of your truck and what fluids you use
NO OPINIONS PLEASE...JUST YEAR OF TRUCK AND FLUID
THANKS
99 1/2 ton 5.3 autotrans auto 4WD
05 2500 HD D-max/Allison push button 4WD
Both have Mobil 1 5W30, 3 qts, filled through the rear ABS sensor hole.
Did both well over a year ago.
Amsoil syn Dextron ATF in the 01, 06 is due it will get the same, 08 is factory fill, only 4k miles on her. Difs are all 85w90 Amsoil syn.
01' push button Tcase...
I think Transynd...I guess since I cant remember I'm due to change it...
2001 LB7 - 2 qts Dex III equivalent ATF (Amsoil 2000 Synthetic ATF) for 3 changes until I got the pump rub wear-through at 124,000 miles. Been running 3 qts of Mobil 1 5W30 synthetic motor oil since.
My 2007 classic has this in the transfer case:
Both the trucks in my signature are push button transfer cases and have the GM fluid bought from the dealership.
I am using mobil one tranny fluid also but since the tranny build I am considering using transynd because I have it on hand. I know that transynd is supposed to be the cats meow for the alli but I am wondering if it has the same benefits when used in the T-case?
