Pruittx2
Been around a bit
Yep you read that right,, I changed the oil in the truck to Mobil 1,, and then was swapping out my glow plugs with some new duratherms,, when I pulled out the second plug on drivers side, I noticed that the element part had oil on it,, Like it 's leaking in the cylinder after shut down. I was able to do all 4 on the left side, thru the fender area with only taking out the rubber flap in there, My truck has a 3 in body life, so with just a 3/8 dirve 10mm socket and a 12in extension, I was able to remove all 4 and replace them in about 15 minutes. The pass side will be a whole other story as the 2 middle plugs have those rusty heat shields covering them, and the down pipe is in the way for the 3rd one on that side.
My downpipe is a Jardine unit, that is 3" down past the frame rail, and then goes to 4' from there back, and it doesn't have the 2 bolts to undo it from the pipe behind that. I'm hoping I can just undo the turbo clamp and the first system hanger, and drop the exhaust enough to reach that #3 plug.
This is a 2.5 year old reman engine from International Diesel. <theysuck>
So can anyone tell me what I'm in for with oil leaking in on my glowplug? :mad2:
