Mikey von
I am going to get a 6.5l oil pump drive to replace the vacuum pump that goes on 6.2l (I will be using the 6.5l serp belt vac pump). The oil pump drives are available with or without RPM sensors.
My question is can I run a tachometer gauge using the oil pump drive with a RPM sensor or is just used for auto tranny computer stuff?
