6.5coalroller
What is the oil pressure supposed to run around. Mine runs around 40 or 45 and a lil lower at idle.
These things normally run about 5o PSI down the road andf idle at about 30
Now this is in perfect shape and with a good direct gauge hooked up.
The factory gauges will give all sorts of readings depending.
The electronic circuitry in the dash can get hinky on these trucks and readings can be quite varied.
I was going to ask why people install an oil pressure gauge, when our truck already has one - but the above quote already answers that question, I suppose.
I'm also wondering, I came across a oil temp gauge looking at - http://www.chiefaircraft.com/airsec/Aircraft/EngineInstruments/ISSPRO.html (while looking at an fuel pressure gauge noted on another post) - and was wondering if anyone has installed that, and why? If the oil pressure or temp goes out of range - what can you do while driving, to get it back into range?
(I'm asking, because I have a A-pillar tri-gauge setup - I need a third gauge (thinking of a post filter - fuel pressure gauge), but I don't think I really need the exhaust temp gauge since I'm not running that high of boost and/or wondering if there is a set of gauges deemed more important than others.
(Sorry if I'm hijacking this thread - I thought it was within the boundaries of the topic)
I'm also wondering, I came across a oil temp gauge looking at - http://www.chiefaircraft.com/airsec/Aircraft/EngineInstruments/ISSPRO.html (while looking at an fuel pressure gauge noted on another post) - and was wondering if anyone has installed that, and why? If the oil pressure or temp goes out of range - what can you do while driving, to get it back into range? QUOTE]
In short, the aftermarket gauges provide a more precise reading of oil pressure. When you can watch a quality mechanical oil pressure gauge similtaneously with the factory gauge, you'll soon trust the aftermarket gauge more.
As for knowing what oil temp is - a significant part of our 6.5's heat shedding ability is thru the oil/oil cooler. It's common to see oil temp edge higher (as engine load increases towing uphill), a bit before coolant temp begins to rise. They'll trend the same direction but changes tend to show earlier in oil temp. Being able to watch how oil pressure varies in relation to oil temp also can give you a better picture of what's going on.
What to do, if oil temps or coolant temps, or EGT get too high? Ease up on the engine before it gets hot enough to damage things. If not enough oil pressure, simply shut it down as soon as you can safely do so, in the hopes of saving the engine.
