Dan Hunter
Truck Terrorist
I had an oil leak on the original lines at the fitting near the cooler not that long ago and went with the factory lines against the body of knowledge here figuring to save a buck and that if the new lines lasted as long as the old ones that would be enough. Wrong. It's leaking again but to keep it interesting they're leaking at the junction on the block side.
I ordered a kit from Greg minutes ago. Live...learn. At least I'll know how to get 'em out this time and it's due for another oil change. I'm just hoping that the drain part waits until I'm on the lift.
