I remember letting them set for a while the last time a few years ago but forgot about it this time.
I read some guys will bend the injector lines. Has any one wrecked theirs doing this?
It's really not that big of a deal to pull the intake but if I don't have to that's better.
I hate stupid mistakes.
Well it looks like Ill be pulling the turbo and intake again. I do have a new cdr ordered if that doesn't fix it it's back into the shop.
Aside from that the motor runs great! I have a long grade going out of town and the egts are 200* cooler than with the old motor. I have to wait until We'd to get it timed.
Is the desired and actual timing setable on the obd1 or is it programmed into the ECM like an obd2?
I'm going to have it set to about -1.5 . -1.9 is pretty loud. I camp a lot and when you fire it up early in the am it wakes up the whole camp ground.
I use a wee bit dif approach with the valve covers.
Scrape and sand both head and cover mating surfaces squeeky clean.
straiten mating surface of cover with hammer and a strip of flat bar or on the edge of the work bench..
Wipe both head and cover with brakcleen.
Apply a 1/4' to 5/16" bead of black RTV to the cover channel,make sure to surround the bolt holes.
Carefully lower the cover on the head without smearing the RTV all over the place( i use a couple guide studs or drill bits in the bolt holes)
Run all bolts in alternatly and evenly till hand tight with a socket and extension.
Leave it sit for a couple hours so the RTV has time to set,...torque bolts to soec.
Don't run the engine till the RTV is fully cured (next day is fine).
Your covers are garanteed to never leak again
No fuel filter, yikes.
