Rodd
Recruit
Well it is done. I replaced my oil cooler w/ the one from Lubrication Specialist. I will try to detail it out w/ pics so the next guy who wants to attempt this mod will have an easier time that me. It really wasn't that difficult. I didn't think it was going to be that dirty of a job. Boy was I mistaken. I did clean up under there but it just allowed me to stay a little cleaner for about 5 more minutes than if I didn't clean at all.
I will try and do this in order so hopefully y'all will understand.
1. Use some engine cleaner and a pressure washer. Unfortunatly when I got started my gas can was out to gas so no pressure washer. I just used the hose w/ a pressure attatchment. Worked but not as well as I would have like. I also used some brake cleaner. That seemed to work best but gets expensive. I got the tech brake cleaner from wally world for $1.96.
1.1. Drain the oil!
2. Remove the front cover/grill to expose the Oil cooler. There are 4 screws that take a 5/32 hex to remove. There is a white tab on the left and right sides that comes up from cover onto the black frame. There are 2 more approximatly 12" in from the outside screws. They are set back in a little cubby hole.
3. There are 3 tabs, one on each side and one in the center that hold the bottom down. I sqoze my arm in from the top and lifted the connectors that hold the tabs to the frame/bumper.
4. Disconnect the 3 light on each side. The outside ones twist and pull out. The 2 inside ones on each side you push a tab and twist to remove.
5. Here is the grill removed. You can see the oil cooler on the right, the trans cooler on the left, the a/c condesor (I think) behind them, and then the radiator just before the fan. (I may have gotten the a/c condensor and the radiator mixed up. I didn't pay much attention to which was which.
6. Unscrew the oil cooler. There are 4 bolts at each corner. I think they are 10 mm. I tried to disconnect the lines from the cooler but they wouln't come. So, I removed the plastic cover in the right whole on the bumper. Then I used my sawzall to cut the lines. It would probably be easier to saw them prior to unscrewing the bolts so the lines are firm and don't move. You will get some oil leaking out so have something ready to catch the oil.
"Continued"
1.1. Drain the oil!
"Continued"
