BigBlueChevy
Compression Ignition Addict
Hey all,
Browsing around for new projects for the truck I stumbled on a site that makes special heavy duty front coil springs for my truck. They are direct replacemtents, but heres the catch - they have an aditional 1000lbs of carrying capacity compared to the OEMs. Very useful for people who add heavy front bumpers and plows to the fronts of there trucks. But what if the truck has neither of these...
This is where my IFS project comes into place. Naturally, with more carrying capacity this WILL lift the front of the truck. So I decided to work some numbers and see what came up with what kind of lifting.
Stock-
Front of license plate holder is 16.5" from the ground
Wheel well(measured from outside at bottom of chrome outline) is 34" to ground
Coil springs measure 6" between control arms and frame rail.
The image below the steering and suspension assembly under a stock setup. No lift, and no aftermarket loads(IE plow, bumper brushguard) Notice angles of steering linkage and control arm to wheel assembly.
By jacking up the front end using the "skid plate", I was able to simulate what a 3" lift would not only look like, but what it would do to a stock suspension and steering parts.
The only concern to me right now is the steering linkage and control arm to wheel linkage angle. Here are pictures I took of the whole assembly under 3" "lift". Notice the angle of the steering linkage as well as the connection from the control arm to the wheel assembly itself
Sway bars show no signs of stress or strain. Only problem right now is the above mentioned. The control arms after the "lift" are now 7" apart from the frame rail. Seems to be for every 1" added to the coils it adds 3" to the truck itself, or a 3:1 ratio, thanks to coil placement.
Rear end is easy. Measurments showed that there is already a 2" difference in height between the front and back.(Damn racecar stance). So longer U-bolts and a 1" spacer block will fix that up no problem.
I'd say a 3" lift on the old girl looks good, how bout you guys?:thumbsup:
Stock-
