OBD1 Computer and Associated Sensors and Harnesses
88 Ford
San Diego, CA
I am looking for a complete OBD1 computer and the sensors and harnesses to adapt to my Ford IDI. I will also buy individual parts as well. I also plan to fix the PMD transistor issues after I get everything adapted so this will help contribute to the cause. Lol. FYI I know the Ds4 spins the opposite direction but I have a plan for that as well. Anyway let me know if you have what I need. Thanks in advance.
Additionally, if you see it at a junk yard, let me know how much and we can work out something to compensate for picking it up.
The obd1 uses a db2 all mechanical pump. Obd2 to use the DS4 / pmd system.
If you "fix the pmd issue" you will make A few hundred thousand dollars off It. Good luck, and hope you succeed.
Also I'm hoping the PMD fix can be corrected using surface mount components. It'll be interesting once I have everything I need.
94-95 are OBD1, and use a DS4 pump. DS4 pumps did not start with OBD2, but instead when the new emission regs kicked in for the 94 model year(the same year DODGE went to the CUMMINS with a P7100 injection pump, and FORD went to the powerstroke). DB2 trucks were barely considered OBD1 even since the manual trans trucks had no controller, and the autos only had a controller for the trans.
Thank you for the clarification.
Maybe I'll just have to see if I can get the part numbers for the harnesses and sensors and buy them that way. Would that be hard to get the past numbers for that stuff?
