kachurak
Well, if I had any hair left, I'd have pulled it out by now.
The last few days I've had some pretty cold weather (15F degrees or so) in Watertown, NY. I noticed that my shift lever would shift into gear with a little bit of effort.
Yesterday morning, I went out to the truck, started it right up, went to put in gear (R) and was able to do it, again, with a little effort (resistance). Put it into (D), again, a little resistance. Moved the truck about 2 feet forward, and it stalled. Not sure why, so I put it in (P) again and attempted to restart it. Well, this time, it wouldn't start.
Realized that the shift lever indicator didn't show any gear change, nor the highlight of the indication of what gear it was in. Flashbacks from this happening before, led me to believe it was the same thing again. The truck will crank, but never turn over and start. I knew the NSB switch (GM part # 29540479) was affecting it, so I located another one ($121, United Auto Supply, Cicero, NY) and put it on the truck. figuring it would resolve my problem and get everything back, it failed. Same thing, it will crank but never start. Something is obviously making the truck think it's in gear and won't crank (what the dealer said). I know mechanically operating though, the truck will move when in neutral, but not in any other position when I change the shift lever, so mechanically, it appears to be ok.(?)
So I'm really stuck on this guys, not knowing where to go with it. I guess what I'm looking for is any input as to what could be happening, if the connectors or any other electrical problems could be causing it. I get no indication on the service engine light, don't hear any additional chimes or anything other than normal. The only thing I can think of is maybe the wires somewhere are shorting, but it seems to look fine. Does anyone out there know what the 4-pin and 7-pin connectors that connect to the NSB switch should show for voltage? Any ideas on what else to do here woud be great - Thanks in advance!
