FellowTraveler
1) (one) Nice late model NP246 Autotrac has encoder motor, 3 speed sensors and front driveshaft $650. +S&H,
1) (one) Front 9.25" IFS differential 4.10:1 ratio, (late model) w/additional pinion bearing lube feed & heavy case (more webbing) w/ARB air locker "just redone" w/new air engage hub on carrier and bearings, the ARB carrier works w/any ratio gear set. I'll include two new outer axle seals because they are hard to get (months) w/o manufacture defects "seal canted in bore", GM & everyone else no matter the brand seem to be using the same manufacture so it's a supply wide issue." $1,100. + S&H
1) (one) Front 9.25" differential 4.10:1 ratio, (early model). $350. + S&H
"TRANSMISSION & T-CASE ADAPTER NOT INCLUDED"
KEEP IN MID THESE ITEMS ARE HEAVY & SHIPPING COSTS ARE HIGH
PAYPAL & USPS money orders accepted.
