valyidol
Active Member
Hi!
My friend from Kazan bought a tow truck Chevy Silverado 3500 1994 6.5 turbodiesel.
Under the hood was IP DB2 but engine worked not so good. Sometimes truck rans well, sometimes not accelerated. And automatic transmission don't work correctly. My friend asked me to replace the pump and install DS4. All wiring for the DS4 has under the hood, and I have a good pump and PMD. I installed the IP and connected all connectors and began to cranking to remove the air. No result! Shut-off solenoid works, lift pump works but no fuel in injectors. What could it be?
On the engine is not original fuel filter and is not t-valve. From filter is dripping fuel, I think the seal is bad.
