matuva
Tropical 6.5er
Hi Guys (and girls ),
I'm a bit lost:
I and a mechanic rerceived one of our beloved 6.5. It' a 1995 S engine which was experiencing erratic stalling.
I thought myself, mmm, another PMD story...
Looking closer, I saw the PMD was already relocated behind the grill, it's a Stanadyne, 2 years old from new.
We found there was a kind of lack of oil in the engine, and had to add about3.5 liters of fresh oil to get some on the oil stick I wonder how the engine didn't seized...
I thought : oil pressure switch. => We put a new ACDelco OPS, check :
. oil,
. fuel pump and put a new fuel filter,
. grounds,
. get rid of the RF filter on the optic sensor harness
She started at first crank, ran strong during the 1/2 an hour road test.
We called the owner, explained him that he should, time to time, check oil level. He cionfess he didn't check anything till he owns the truck (about 3 months), and, I'm not sure, but I believe he was poking at fub when he asked "where do pour in oil?" :skep:
That being said, he sat in the truck, crank and start... then dies. She did that 4 times, crank-start and die...and now she absolutely refused to start...
We found no fuel is coming at the injectors. So we tried :
. 2 brand new PMDs with new harness or connected at stock plug;
. hotwire the lift pump
. Brand new ACDelco CPS,
. new fuel shut off solenoid, and check its fuse
. disconnect plug to optic sensor to initiate limp mode
. disconnect CTS on T-stat housing
. batteries are new and starter pushes strong.
Result is plenty of fuel at the bleeding T-valve, not a drop at injectors... and no start...:???::???::???:
Any thought?
I'm a bit lost:
. oil,
. grounds,
Any thought?
