matuva
Tropical 6.5er
Good day all,
A friend of mine bought the exact same Blazer than mine (except mine is the nicest one of course )
He exchanged her with his K1500 pickup and was happy with the deal.
Then the Blazer started stalling and finally didn't start.
Put a new PMD and extension, I hot wierd the lift pump, and she started again, for 2 days, then she stalled again several times, and now doesn't start anymore.
So, obviously, the injectors get no fuel : IP?, PCM?
No DTC stored, I also noticed "service engine soon" lamp blinking, and very quick to no glow cycle.
I must say I'm a bit loss :???:
- I checked all fuses : OK
- I tried the PMD & extension on my own Blazer : starts very easy and iddle/run fine
- check LP, plenty of fuel at the IP inlet
- pull out the Fuel shut off solenoid: works OK
- crank an injector : no fuel
- disconnect CPS and optic sensor : no start, not even limp mode
- absolutely no smoke at the exhaust
- grounds look fine, though I told him to clean all of them : to be done soon
- good batteries and starter spins strong
