:iagree:The 83 is a mechanical lift pump.
The only way to do this easy is like this.
Unplug the large red wire from the IP to stop the fuel solenoid from actuating.
Open the bleed screw on the filter and crank the engine until air free fuel comes out.
Close the bleeder and plug the power back to the IP.
Glow the thing and crank it. If you have cranked it otherwise you have air in the pump and the injectors.
Not a biggy but will take a little cranking to get it up and going. Normally these will prime right up and dont need a lot of fussing.
Let us know.
MGW
