Forgive me for making this my first post. I found this board due to the troubles I am having.
1993 C2500 (Air Force) 6.2L Diesel 3/4 Ton
The truck was surging and sometimes spontaneously dying while driving. It would start back up and drive again. Sometimes the surging would go away, sometimes not. Changed the fuel (lift) pump and the filter. Now the truck will not start at all.
I checked voltage to the pump and got nothing, so I checked at the box where the gray wire that runs to the pump enters the box (forgive my ignorance but I don't know what the box mounted on the firewall is). Continuity but still no voltage when turning the key over. What else can I check or what is likely to be the problem? Checked all fuses, although there are a number of empty slots.
Any help is greatly appreciated!
