matuva
Tropical 6.5er
We put a fresh rebuild engine, connect everything, then crank to bleed IP, and have nothing at injectors : nothing, rien, nada, ничего 何も :mad2:
we have fuel at he IP inlet, fuel filter manager well bleeded, full of fuel, plenty of fuel dripping out the Bleeding valve of the FFM
We tried two other PMD, new ones
new extension harnesses, or straight on OE harness
new CPS
new fuel shut off solenoid
check all grounds, fuses
check all connectors in harness in case we could have bent a prong
hot wired lift pump
IP? ... :???:
new CPS
hot wired lift pump
IP? ... :???:
