no front or rear heater blower.
hereismylife
formerly j k auto
pa
They just quit working. Checked the fuses. Number 12 fuse is getting no power. Is there a relay or what might be going on.
Thanks
Check the connector behind the glove box for burning up and then check the main blower switch.
If I jump the #12 fuse on drivers side panel for the batt the blower comes on. The first time we jumped it..it worked for normal with key for 5 min then stopped working again.
Does the wire behind the glove box tie in with the back blower?
I'm assuming this is the 95 in your sig? I will pull up the wiring diagrams and trace it out here in a little while and see how power is routed to the circuit for you.
I looked at the wiring diagrams in my ALLDATA, and it looks like you need to check the 50 amp IGN B fuse in the underhood fuse panel. If it is good you need to check your ignition switch to make sure it is switching the IGN B circuit power. And if it is working check your fuse panal bus bar.
K will do...thanks....I do know I don't have power at fuse on side of dash.
Do you know what color wire should be at the ignition? 50 under hood has power and if you put power to number 12 fuse everything works fine.
