no DTR lights, no dash lights ....
VW_Lupo_TD
Active Member
in quiet
too worn out to look it up right now, will someone just tell me
if it is just a fuse if there are no DTR (daytime running) lights
or whatever you call the orange lights and no dash lights.
i am suspecting it is just a fuse, but after unloading the entire 20 foot haulmark by myself, i cannot get up anymore....
thanks
I think there is a fuse in the fuse panel in the dash for the DTR and a relay in the convenience center under the dash for them as well. Do the lights work when you turn them on with the switch? I know if your parking brake is even slightly engaged it will turn them off as well.
ON EDIT: It sounds like you are talking about the running lights fuse, if so then yes it has a fuse in the fuse panel inside the truck. Not sure about 94, but my 95 is fuse #9 inside and is a 20 amp.
Daytime running lights have thier own fuse. I removed it on my 2000 however I'm surprised your 94 has them. My 95 didn't but then again my 95 was like a municipal edition. Didn't have alot of things but the 96 I drive at work does not have them either.
94 has DRL? Mine doesnt? none of my old ones did. (6 and up I cut a tap off the relay so they dont work. hate headlights when you need parking lights
parking light fuse is in the fuse panel right by the hood release
twas the switch.
those are fun, i think i went threw 6 off them before i cut the wires and made my own with relays
