ghostrider500
Always stirrin' the pot
Ok... to start off I don't know if my brake lights were working before I started what I'm about to describe below.
Bought a new to me car trailer and redid all the lights and made it a seven blade plug. I had a old bumper plug on the truck that was a six wired into a 4 flat that was plugged into the weather pack by way of an aftermarket "T" inserted between the connectors of the pack. Bumper plug was old and crusty and went about replacing it with a new seven blade. Already have a seven blade in the bed for the fifth wheel and works great. Stupidly decided to splice into the 4 flat wiring and then the orange and blue wires routed to the back from the factory. Spliced wrong and put right turn into ground. :mad2: Never checked brakes at this point. Popped the fuse at the dash 20amp. Rethought my hastiness and went back to the factory wire harness that the fifth wheel plug is connected to and did it right this time. Everything works except for brake lights. Have tails, turns, 4ways, but no tails. This is with no trailer plugged in. Checked 20amp fuse at dash and is good, replaced it anyway and still no brakes. Looked at the brake relay, but not sure how to test it. did give it the sniff test and didn't smell burned.
The thing that has me confused is that my third brake light works and my brake controller recognizes when the pedal is engaged when a trailer is plugged in. I've replaced the brake position sensor(?) that is under the dash about five years ago and when it quit I'm pretty sure the third brake light and brake controller didn't work either. My questions would be:
1. Third brake light and brake lights are connected?
2. How does one test a brake relay or is it just easier to replace?
3. Brake position sensor bad test? What a PITA this was to replace.
Any and all anwers appreciated.
