I've seen references to the mess people sometimes find when they remove the intake manifold on a 6.5 TD. They mention decayed vacuum lines, and other items damaged by long-term heat exposure.
I have to replace my corroded fuel lines and failed LP. While I was at it, I figured I should also do FTB. That entails pulling the intake manifold. Once I have the intake manifold off, what should I look for? What should I replace while I have access?
I'm assembling the parts I need for this project, in hopes of minimizing shopping trips while the truck is in pieces. I have the intake manifold gaskets. The fuel line, Walbro, fuel fittings, plenum gasket, vacuum/pressure gauge, needle valve, and fuel fittings are all on order. It sounds like I should also have some vacuum line handy. I'm about to order the FTB kit and NPT tap. What else should I have on hand? What surprises typically lurk in what I've heard people call "Death Valley"?
I did look for threads on this, but came up dry. Perhaps I just don't have the right vocabulary yet. I'd appreciate any pointers.
I have a '99 C3500 6.5TD with manual transmission. Lift pump has power but doesn't move fuel. Fuel line fittings are too corroded to use. I'm planning to put in fuel hose instead. (I hate corrosion.) PO replaced cluch and tranny, and had engine serviced & filters replaced 6 months ago. Truck has frame rust, but drive train is great. (As long as I don't try to bleed water from the filter with a dead LP.)
Thanks,
-jpg
Thanks,
-jpg
