New or rebuilt injectors
SnowDrift
Ultra Conservative. ULTRA!
Central Ohio map dot
It is sounding like I am faced with the decision to buy a new set of injectors or have mine rebuilt. Bosch nozzles have been recommended and there is still debate on what pressure to run. I'm currently using a DS4 pump but my hope and plan is to eventually get to a DB2 pump. If I go with new, is there a recommended supplier where the parts are not some chinese imported knock-off? I have a vendor or two in mind but wanted to hear what the consensus is as of today.
Whatever you install. Make sure they're tested and balanced.
I heard John Faddis sells them tested and balanced. I don't know if that's true or not
He did have those on his web store but I have not seen them in a while.
Might send them an email and see if they would work up a set for You.
If they will not then buy a set of their, or Leroy Diesel new injectors and get them tested and bLanced before installing them.
Maybe @dbrannon79 is now set up well enough to do the job. If not then send me a PM and I’ll give You the number and addy of a shop near me that does an excellent job.
I had Joe do the injectors I had removed from my old engine and now there is not one puff of smoke on the coldest start ups.
I can test and adjust them. have a bunch of shims too. I'm still in the learning process playing with these old used ones. if someone would like me to set some up I wouldn't charge anything, it would be free for any of yall :)
