tammlyn
Active Member
be careful guys ,there is a new regulation that whent in effect on july 1 2012 in ontario canada,i have a dually and i now must install a yellow sticker,the rules used to say that as long as your plating was under 4500kg,and your trucks weight was under 4500kg you were ok when pulling a camper or fifth wheel,now if the manufacters rating exeeds 4500kg you must install a yellow sticker it doesn't matter if your towing or grocery shopping i have three friends that have been charged its a 240.00 fine the ministry opened the door on the truck it said 11400lbs or 5100kg if you don't have a yellow sticker you get a fine ,one was actually charged by a city cop thanks mike
