6.5L
Old Iron Runner
Well I purchased an ATT a while back, install went fantastic. Only took four hours but I messed with some other stuff too. A great drop in kit. I am not ragging on the ATT at all but I am having some major spooling issues with the turbo. It will only spool roughly 4-5psi max between 3000rpm and 3500rpm. And even then my pump is de-fueling at 3400rpm. So I have a very brief window. I don't think this is right. I thought maybe I wasn't getting enough fuel so I turned my pump up another quarter turn, so it would be half way in. Nothing at all changed except bad mileage and high EGT's. I cruise down the road at anywhere between 850 and 1000 degree's pre-turbo. Seems very high compared to my GM-3. So I ripped my crossover pipe, it checked out perfectly fine. Checked for intake leaks, still nothing. Checked for exhaust leaks, still came back fine. Somewhere something is gonna give before this works. I just purchased a motor from Teds Trucks. Should be here this week. I thought maybe an injection pump problem delivering fuel, so I am tearing that off and having it sent to Rapid Diesel in Basin for a complete rebuild. I hope it has the upgraded internals for my checkbook's benefit. I am gonna check the turbo this coming week to make sure the internals are ok, and that the wheels are not spinning independently of each other, but I am sure they are fine. I am more convinced of motor than turbo, but who knows. With a 8000lb trailer my boost doesn't change at all and EGT's cross over into the scary point. I can do 80mph and still not build a single PSI. Any suggestions?
