adamhammer
Hi,
just got my truck back together(had it apart 2 months). spent 14 hrs today doing final bolt-up and trying to start the truck. I've followed procedures to bleed the filter, bleed the fuel drain line, and crack the injector lines while cranking to get rid of as much air. the only thing I did not do was remove the glow plugs. I am getting fuel at the lines(5 of 8 that I could crack open). 3 hours later still no start. The PMD is 5k miles old, relocated to the top of the intake, this was done by the previous owner. I bought the truck with a diagnosed IP overrev problem. I noticed the pmd was rather warm while trying to start, do these generate heat?. I've cleaned all grounds and glow plug module connections. I even tried some wd-40 to see if that would kick something off, but no luck. any ideas? It would be great if someone was available sunday afternoon to help troubleshoot over the phone.
Thanks,
Adam
Thanks,
Adam
