toddlnrd
My first diesel!
I am going to install my new/rebuilt injector pump tomorrow.
Any advice, tips or links would be very helpful.
Thank you,
Todd
Thank you,
Todd
Also the 3 bolts in the IP timing gear are spaced so that they will only bolt up one way. The dowel can find the 'other' hole but the bolts will make sure it's timed.
The only real danger is dropping a bolt down into the timing cover... and the milk crate slipping out from under you..
