Danish Farmer
Bought a new GP relay but the pins are different from the old one.
The old one has three pins (in the outlets number three, four and five, counting from drivers side.) (Dont know the age of it)
The new one has four pins in the outlets one, two, three, four.
Shapes of the new one tells that the plug has to be rotated 180 degrees before it will fit in the grooves. (The thick and thin groove that prevents the plug to be mounted wrong)
Anyhow, GP light does not come on, no click, and SES code 29 (GP relay cirkuit fault) is comming up.
Fuse is ok, and I got battery power at the big wire going into the GP relay.
The plug has a pink, yellow and black wire, and when the key is at glow position, I got power at the pink one too.
Can I get any use of the new relay, that looks identic to the old one and was bought by a prof. dealer.
When remounting the old one again, same code is coming up, and will not be erased.
Any adwice from the 6,5 gyes ?
New to the left, Old/original to the right
