New extended drain CJ-4 oils from Amsoil!
Wrecker
The Oil Geek
Beaver Falls, PA
AMSOIL Boosts CJ-4 Diesel Oil Offering:
AMSOIL has reformulated its Premium API CJ-4 Synthetic 5W-40 Diesel Oil (DEO). In addition, AMSOIL now offers a new 15W-40 Premium API CJ-4 Synthetic Diesel Oil (DME). These exceptional diesel oils provide a level of protection afforded only by a truly high-quality synthetic oil – and do so over drain intervals of three times the OEM recommended drain interval. They are the premium choice for API CJ-4 emission-compliant diesel oil required by model-year 2007 and newer diesel engines. Formulated for vehicles fitted with exhaust treatment devices, DEO and DME are also backwards compatible, offering maximum protection to all diesel applications
We've been using DEO in our trucks (signature) for a while now. Is there any reason to go to the new 15W-40? We liked the better cold start lubricity that the 5W-40 offered...
Ashton,
Thanks for the information...I see that the Oil is reverse compatible, so the Older trucks as well as LMM equipped trucks will benefit from it's use...
DEO is just fine for your applications, I can't see any reason for you guys to switch.
Are they still offering both the new 15w-40 and the old 15w-40 ?
or
Is this going to just plain be the 15w-40 ?
now this new oil being formulated for treated exhaust systems how is that going to effect trucks with untreated exhaust systems ?
Mikey
Yes, both AME and DME are available, but the new DEO is reverse compatible with older applications also.
I think i am going to stick with my AHR for now. . .But the DEO seem to be and rather interesting product. . .
Mike
