revyd
- Messages
- 7
- Reaction score
- 22
New to this forum and relatively new to the 6.5 although I've had a GMT400 for at least 20years.
My truck is a 1995 Silverado K3500 dually. A previous owner made some mods that have been disastrous. He put electric fans on the tranny and oil cooler then took off the fan clutch and replaced it with a flex fan, and needless to say had some serious heat issues. I got rid of the electric fans, changed out the water pump to a newer version, put in a hayden severe duty fan clutch and a duramax fan. Overheating issues gone. However the damage was done so now I have a new used motor. I replaced the oil cooler lines with some custom lines and added an HO cooler from a 98. I relocated the oil filter and added a new 2.5" crossover pipe. Since then it's been pretty reliable except for one thing.
On very random occasions right after I start it, usually just after I put it in gear and start moving, it stalls. It doesn't seem to matter if it's hot or cold and it has never done it to me while I"ve been driving. I've gone through all the grounds, I put in a new lift pump but it's still happening. I don't get a check engine light but I have to crank it quite a bit to get it to start after it stalls. My suspicion is fuel but I don't know where to start.
